- Dec 26, 2016
- 2,027
As far as I know the sensitivity adjustment on the HF / PA helmets works best at its highest setting, and leaving it in the sun once should be alright for quite a while,.
I have had two HF type , accouple of lower end Lincoln helmets and they all performed equally well, the Lincoln did benefit being in the sun for a couple of hours but once only and it was fine for the next2-3 years but I was using it 2-3 times a week though.
If there's an issue other than setting to the correct sensitivity, then its time to return the helmet. I would also check if there's a new battery in it .
Where I worked my last job the company offered to buy Speedglas hoods for us and take off $50 per paycheck until it was paid in full.I got one and wow, it was(and still is) a pleasure to use, light weight, comfortable, responsive to each level of sensitivity, and very expensive but to this day it has been my "go to" helmet .
