- Feb 5, 2018
- 638
I would guess you had your hands between the sensor and the weld. I have seen it many times at work. Usually by people with terrible eyesight that get really close.
Joe
Joe
Do tell which one you got when you finally gave in?I was leery of them for years but finally gave in and bought one after using friends el cheapo. I got a better one. I truly wish I had made the move years ago. Adjustable trigger setting, trigger time, shade, four sensors, large view and 'true colour'. Add to this that it has a super light weight shell and has one of the best head straps I have worn. Absolutely love it and my welds are nearly as good as they used to be because I can see what I am doing. Welder nod buggered my neck and now I don't have to worry.
This is because an auto dark lense blocks 100% UV and IR regardless of whether it's triggered or not. Intense visible light is not great for your eyes, but not damaging like getting blasted with full IR and UV which actually gives you burns.
Thanks Rick, all is well this morning. It definitely freaked me out.@DavidR8 , I hope your spot goes away right quick. That would freak me out. I thought that a dead battery would default to a dark shield? Sometimes I will see a little flash as amps taper way down at the end of a bead because the light output is so little. Never in a way that is uncomfortable. As stated, I think the UV and IR rejection is intact. you should call the manufacturer of the helmet to try to understand what happened and how to make it not happen again. I'm sorry to hear that happened.
Thanks, it's a new Esab A40 Savage. I think the problem is that I had the sensitivity down too low and I may have been inadvertently blocking one (or more) of the four sensors.I had a couple ok helmets I used a lot for mig and never had any issues, but when I started tig welding, especially thin material with low amps I got an occasional flash. I decided to invest in a better helmet and bought a Lincoln 3350 series. Never had another issue. Really like the helmet and it's hard to put $ value on you eye heath and safety. Don't know what you're using now but a good helmet is a good investment and worth every penny.
