This thread got me to thinking.
anic: This HF tool might have a use after all.
http://www.harborfreight.com/2-in-mini-bench-top-cut-off-saw-61900.html A 2" cutoff wheel some 1" angle drilled and taped for te screws. If you cut alot of screws.
I have one of those saws. The blade that comes with it, works well with soft metals, I use it for 5/16" brass rod, when making jets for carbs.. Also got a thicker blade for cutting screwdriver slots in the jets. Runs to fast for steel. I did buy some 2" cut-off wheels. HF does not sell them though. Found them on E-bay. They were even recommended for the HF saw, among others.
If you use the wheels for anything above 1/4, that is steel, "Bring Your Lunch". You have to go slow, due to a lack of power from the motor. You cannot put much pressure on the wheel. I used it to split a 7mm threading die. The material was about 3/8" wide and about 3/16" thick. Took me all of 15+ minutes to get through it. Glad I had only one to do. The saw does what it was designed to do. Just not as much as you might like it to. --- John
