- Dec 20, 2012
- 9,422
There are times when I need a screw of an accurate length but holding a small screw can be tough so I came up with a little tool that is very handy.
I can hold up to a #10 screw with just about any head - SHCS, button head, pan head, etc - very solidly for hand grinding or I can chuck it in a lathe and cut the screw to a precise length.
The brass heads have either a flat surface inside the bore or a 82 degree chamfer that will fit a #10 screw. For smaller screws I use a washer sized to fit a #6 or #8 screw to center the screw in the head. When the head is threaded on to the shank of either the hand tool or the shorter bar that chucks into the lathe the nose of the tool pushes the screw solidly into contact with the inside of the head and the screw is held very solidly.
For storage, one of the heads remains on the nose of the hand tool and the other, with washers inside, simply screws onto a retaining screw in the handle.
This tool works very well and holds the screw very solidly with just hand pressure on the head. Anything that distances your hand from a grinding wheel or belt is a good thing, right?
