- May 7, 2023
- 1,338
Thank you. I missed the point the first time.
If I understand correctly, the tiny breather hole is in one wall of the tube and inside the bottle.
When squeezing to dispense, a small amount of fluid bleeds out of the breather hole (but back into the bottle) and when finished dispensing, the breather hole is above the liquid level, so the air volume is vented to atmosphere and won't "pump" regardless of delta T.
That is an excellent solution to the OEM PITA I described. I wish I had thought of it and I can't believe it's not an OEM feature.
Correct.
don't know why, but I don't have the problem with mine. One has Alcohol, and the other WD-40.. neither leak out.
I don’t have an issue in my basement shop, but when I would take that bottle into the garage it could sometimes be an issue and with it being a volitile liquid it took paint bubbling on a piece of equipment to know it was even happening.
