- Sep 18, 2023
- 28
I have cut a rectangular steel tube as close to having true corners as I can manage with the tools I have. Thanks to people who provided help on an earlier thread about this!
What I have is probably good enough for my application, but I’m enjoying learning, so I’d like to further refine a bit more.
When I place the cut tube on a glass sheet, it rocks diagonally from one set of corners and not the other. Here is a picture to illustrate:
It rocks back and forth with the O points alternately touching. The X points don’t rock.
I’m having a tough time visualizing where I’d need to remove material to make it not rock.
To make it easier to answer, here is a diagram. I could remove material at the points, or on parts of a line. So you could say: file at point X or remove material on the line XY closer to Y, for example.
Just to say it, I know that flattening it might leave it not square/could have a tilt.
