Harbor Freight milling machine drum switch wiring
I hope I posted enough info for you to put yours back together. That was my intention. My mill works perfectly since the switch was put back together. Ya, I did put a lot of work into it, I kinda took a long route, but once I got the info in post #22, I then figured out how to rewire the original switch.
If you just want to take the easy route, wire it as in post #22.
Mikek
Well, got my jumpers made and installed. I'll hook it up tomorrow and post results ! Huge thanks !
Mikek
Well... some success. I can either get it to go clockwise in both switch positions or counterclockwise in both switch positions ... I've tried flipping the wires to the switch but no change. My wire colors in the back are different than yours.
I missed your responses in my email, or didn't get them ;-/ I'm busy right now, I'll think about this and get back to you.
Mikek
Hi Brady- you're running this on 110/120 volts right? I'm not sure your switch is the same as Qs
Having the two blue wires makes it difficult to figure out
I might have some info on this- I'll take a look
I am running it 110v. One of the blue wires has a sleeve with green lines on it and one has orange. Check out the pic I posted above
OK I see- that means that the two with orange are the start wires and the two with green are the run/main wires
That helps some, but we're kind of guessing on the switch innards
I still suspect the switches may not match- they come in different flavors
Here's a sketch I did for another member who also had a blue switch
For your mill the two orange sleeve wires would go to Z1 & Z2 and the two green sleeve wires to U & V
The truth table and wiring are combined on one page. 10 jumper wires total.
The Xs show a connection, for example in Forward 1 & 2 are connected. In Reverse 3 & 4 are connected and so on.
If your switch is the same it should work for you:
The truth table and wiring are combined on one page. I think 10 jumper wires are needed.
The Xs show a connection, for example in Forward the 1 & 2 are connected. In Reverse 3 & 4 are connected and so on.
Awesome! I'll give that a try today !!! Thanks !!
