- Apr 23, 2018
- 6,541
I hate when that happens. I'm not visualizing the 8-32s going into a 6-32 being loose.
Oh, it was the other way around, my threads were bigger than the bolts. I set back up, found center, and counterdrilled and counterbored for the larger bolts and all is well.
But my day didn't end there.
I made another blunder today that I am not going to be able to recover from. I set up that fancy xx claro walnut stock on the mill in order to cut an inlet for the Anschutz rail in the fore end. I made a beautiful slip-fit channel for the whole rail. I used my new chinese calipers to lay out the line. Now, the stock is a custom job, not a CNC mass produced stock, so it's really hard to find straight lines to measure from to begin with. Nothing is square to fix from. Fussing and fiddling, it wasn't until it was cut, off the machine, and in my hands... I was off center by .233 inch... just ducky. What the hell, I measured. Oh, I was just using the calipers on the last project in INCR mode to include a .233 offset... and I didn't put it back in ABS mode before laying out. I guess some lessons are learned the hard way, but I won't be making that mistake again. Maybe I'll re-make the hand stop rail wider and re-set the feature. That sounds pretty good...
