    Dismiss Notice
Goofs & Blunders You Should Avoid.
Discussion in 'GOOFS & BLUNDERS YOU SHOULD AVOID!' started by David S, Jul 24, 2016.
  1. David S
    David S Canada Active User H-M Supporter-Premium
    530
    113
    Brockville, Ontario
    City:
    Brockville
    State:
    Ontario
    -Return to Top-
    Forget my previous smart ass thread and lets see if we can contribute to the OP's original intent.
    I do a lot of machining with small drill bits, cutters etc on my drill / mill.
    When chucking up a very small diameter drill bit in a 13 mm three jaw chuck it is very easy to get the chuck to tighten down on the bit when it is between just two jaws and not centered among the three.
    Turning on the press without first doing a manual sweep can break the bit or damage the work piece.
    Always rotate the chuck after tightening by hand to check clearance.
    David
    Coolb and Ulma Doctor like this.
  2. T Bredehoft
    T Bredehoft Active User H-M Supporter-Premium
    1,110
    113
    Central Ohio
    City:
    St. Louisville
    State:
    Ohio
    -Return to Top-
    I've found that seating the back end of the drill bit in the back of the chuck makes centering the drill bit a little easier. Of course, if the drill is shorter than the depth of the chuck this doesn't work.
    In the spirit of blunder. I have had the following experience. I needed to drill two .040 holes in a piece of aluminum, 3/16 thick. After breaking three or four drills I realized that the hand feed on my mill was not sensitive enough for me to feel when the bit was in aluminum, and i'd jam it into the material before slowing the feed. Talk about ham handed.
    RVJimD and Ulma Doctor like this.
  3. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,065
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    I am game, made a few errors over the years.
    Do not leave the drawbar wrench on the drawbar and then turn the spindle on with a Bridgeport type mill. This I have done in the past, I am short in stature however and no harm was done.
    Turning the spindle on when it is holding an indicator is not recommended.
    The last few years I have been programming CNC lathes, rapid moves go from the current position to the start position in a hurry, I have managed to break 2 parting tools so far, I have no problem with parting operations I do seem to bugger the rapid moves however.
  4. Ulma Doctor
    Ulma Doctor Infinitely Curious H-M Supporter-Premium
    2,337
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    don't leave the handle for your shop press in the jack, it'll poke your eye out- i had to explain that to a new work trainee, because i almost poked my eye with the handle he left in the jack.
    don't mix synthetic grease with non-synthetic grease, you'll replace bearings soon after. i repair machines that are routinely ruined by operators not knowing that.
    don't ever think that you know enough to not take advise.
  5. Wreck™Wreck
    1,065
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    As a side note, if you ever run a large lathe/mill with powered rapid controls do not place your kneecaps near the hand wheels and engage this feature as it will easily hurt you a good deal and may break some bones.
    Martin W, Ulma Doctor and 4gsr like this.
  6. brino
    brino Active User H-M Supporter-Premium
    1,856
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    Yesterday I was wondering what was wrong with my drill operation, it just wasn't working right.......and then realized the bit was spinning backward!
    Some years ago I had installed a reverse switch on my drill press.....don't exactly remember why I needed it.
    Apparently I had managed to toggle the rocker switch when I moved the drill press around the shop last week.
    -brino
    Round in circles and lens42 like this.
  7. astjp2
    astjp2 United States Active User Active Member
    69
    28
    City:
    Pleasant View
    State:
    Utah
    -Return to Top-
    When its -40* don't lock your keys into your vehicle, always have a spare key in your wallet...in case you do.
    GA Gyro and Randall Marx like this.
  8. Reeltor
    Reeltor United States Active User Active Member
    223
    43
    City:
    Lawrenceville
    State:
    Georgia
    -Return to Top-
    It doesn't have to be -40* F for it to be a problem locking your keys in the vehicle. I like the keypad on the driver's door to unlock 1 or all doors. Years ago I had a client lock the doors with the engine running. Next car I bought and all since have the keypad.
  9. astjp2
    69
    28
    City:
    Pleasant View
    State:
    Utah
    -Return to Top-
    Yeah, I can tell that you have not spent much time at -40 from your comment, batteries don't work to well for your keypad unless its heated, hell doors don't even close properly, windows don't roll down, and at -40, locking your keys in is a life threating event...
    royesses and Stirmind like this.
  10. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,537
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Hey, at 100 degrees F and 98% humidity, it's a life threatening event!!!
  11. pineyfolks
    pineyfolks Active User Active Member
    307
    83
    City:
    Dillonvale
    State:
    Ohio
    -Return to Top-
    Take any tooling you're not using out of the tailstock. After running a 3/32 drill half way through my arm in shop class I learned real quick.
  12. TOOLMASTER
    TOOLMASTER you don't want to know Active Member
    1,042
    113
    City:
    SOMEWHERE
    State:
    Minnesota
    -Return to Top-
    only works if you don't leave your wallet in the car...
  13. David S
    530
    113
    Brockville, Ontario
    City:
    Brockville
    State:
    Ontario
    -Return to Top-
    how about clearing swarf on the lathe. Never ever use ones hands to push, clear, untangle the swarf building up. Use a brush to push it away or perhaps smooth handled pliers to try and grab some. The idea is that you don't want the pliers to get caught and pull your hand into the works.
    Best of all turn off machine and remove the swarf and build up.
    David
    Ulma Doctor likes this.
  14. 4gsr
    1,537
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    I have a pair of H-F needle nose pliers at each lathe for removing stringers, balls, etc. from the cutting tools. I learned way early in life, they will slice fingers all the way to the bones! Still give me the hibby-gibbies thinking about it..
  15. Martin W
    Martin W Canada H-M Supporter - Premium Content H-M Supporter-Premium
    137
    43
    City:
    Welland
    State:
    Ontario
    -Return to Top-
    Never ever take a rubber mallet and hit the piece that's turning in the lathe. My former class mate knows this because he lacks his front teeth.
  16. epanzella
    epanzella United States Active User Active Member
    149
    63
    City:
    Higganum
    State:
    Connecticut
    -Return to Top-
    I was drilling a hole in a spinning piece with the tailstock. After checking that the quill was clear of the tooling in the QCTP I began drilling the hole It was a small deep hole so I was pecking and suddenly I heard a rubbing noise. A tool holder was rubbing the spinning chuck. Because I was going slow it barely left a mark but could have been a real crash. I turned out that although the quill was clear, there was a bolt sticking out the bottom f it that was out of view from above. It touched the tooling and It was pushing the whole carriage along with it.
    Round in circles likes this.
  17. Martin W
    137
    43
    City:
    Welland
    State:
    Ontario
    -Return to Top-
    On the weekend I was turning a flange on the face plate. I only had 1/8" clearance between the part and the ways. I made about 4 passes with a boring bar. Then I pulled the lever up to stop the lathe and I cranked the carriage out of the way to measure. The aluminum cover that protects the ways must have been sticking up some on the end and caught the still spinning piece and broke it right off.
    Looks like a tig welding project this week end:(
    Martin W
  18. george wilson
    george wilson United States Global Moderator Staff Member H-M Supporter-Premium
    658
    113
    City:
    Williamsburg
    State:
    Virginia
    -Return to Top-
    Did someone delete MY goof?
    My Hardinge HLVH starts up at 3000 RPM in a half second or so. Forward and reverse are buttons down on the cabinet. To unscrew a collet, I had reversed the lathe. I started the lathe up without looking at it starting,and using a collet to hold the brass rod I was working on. For some reason my tool would not cut. Then,I found out I had left the lathe in reverse!! Give me a chance to learn. I have only been using that lathe since the late 80's!!
    royesses, Ulma Doctor and brino like this.
  19. olcopper
    olcopper H-M Supporter - Premium Content H-M Supporter-Premium
    30
    18
    City:
    Pembroke
    State:
    Georgia
    -Return to Top-
    Don't ever p*** on an electric fence, no matter how many beers you've had and who dares you.
    Never ever leave the chuck wrench in the chuck before turning it on
    kill all the power to a machine before replacing collets. A Mr. Sajo taught me that one!
    Insure you tighten the clamp bolts on a round column mill-drill--took me two 1/2" carbide end mills back to back to learn that one
    And many more
    olcopper
  20. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,071
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    Not life threatening or even machining related but here's one to avoid. Years ago, I was into developing my own color slides. I was in the process of developing the slides from a three week vacation out West and had loaded two rolls of film into a light tight cassette. I set it down to do and another task and, on returning, opened the cassette in bright light to see if I had loaded the film. Doh!:headache:
  21. george wilson
    658
    113
    City:
    Williamsburg
    State:
    Virginia
    -Return to Top-
    Back when I was in about the 2nd grade,I walked daily past a pasture of cows inside an electric fence. I must have leaned on that fence about 3 times,and got a BIGGGG jolt before I remembered to not lean on it while looking at the cows!!!
    There was a bull in a pen across the road from the cows. He was very friendly to me(At least it seemed to be so while I was pulling up grass and feeding it to him. I never got INTO his pen!!!) One day the men were running about pretty alarmed because that VICIOUS BULL had gotten loose!!:)
    royesses, Ulma Doctor and Martin W like this.
  22. MSD0
    MSD0 United States Active Member Active Member
    35
    28
    SF Bay Area
    City:
    Fremont
    State:
    California
    -Return to Top-
    I've done the same thing so many times. A few times I ended up regrinding the tool and checking center before I figured it out.
  23. brino
    1,856
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    I wish someone would delete a few of mine! :grin big:
    -brino
  24. kwilliam
    kwilliam Australia Iron Registered Member
    14
    3
    City:
    Adelaide
    State:
    Outside US / Canada
    -Return to Top-
    I've lost count of the times I've used an edge finder, and forgotten to add the offset.
    I'll learn one day.
  25. Charles Spencer
    Charles Spencer Active User H-M Supporter-Premium
    770
    93
    City:
    Worcester
    State:
    Massachusetts
    -Return to Top-
    Don't put your retirement money into any fund that charges 2% or more per year.
  26. TOOLMASTER
    1,042
    113
    City:
    SOMEWHERE
    State:
    Minnesota
    -Return to Top-
    better yet don't put money in a retirement fund.
    markba633csi likes this.
  27. TOOLMASTER
    1,042
    113
    City:
    SOMEWHERE
    State:
    Minnesota
    -Return to Top-
  28. Franko
    Franko Active User H-M Supporter-Premium
    995
    113
    Richardson, Texas
    City:
    Richardson
    State:
    Texas
    -Return to Top-
    I've learned so much from my mistakes. I'm thinking of making some more.
  29. dulltool17
    dulltool17 United States Active User Active Member
    85
    28
    City:
    Weaverville
    State:
    North Carolina
    -Return to Top-
    A smart man learns from his mistakes; a wise man learns from the mistakes of others.
    This philosophy leads to "lurking" on internet forums....
  30. savarin
    savarin Active User H-M Supporter-Premium
    1,446
    113
    City:
    Townsville
    -Return to Top-
    dont listen for the gas at the tig nozzle when you have a high frequency start.
Share This Page
