- Jan 7, 2016
- 3,278
Hmmmm ... I used a brand new strap rated for 2000 lbs, and by double-looping it (visible in my photos), I got some extra margarine of safety.
It looks like your move went buttery smooth...
I would go larger than 1/2-13....Someone told me that they might just drop it off the side of the road since liftgate service is just that. I've had 2 machines delivered from PM before and both times, they used a pallet jack and asked me where I wanted to put it in my garage.
Have you guys ever had this issue? I hope they at the very least put it on my driveway. Otherwise, if it's on the side of the road, I'd have no way to bring it to my garage.
Also, my plan as of now, if they can't put it inside my garage because of the height of the crate, but set it on my driveway instead, is to take off the top and sides of the crate to allow overhead clearance, then anchor a 1/2-13 eyebolt on my garage floor, then use a come-along to pull the crate from the driveway into my garage using rescue straps rated for 6k lbs.
to allow full head rotation.
The liftgate delivery for my lathe was specified to be just that - curbside only. When they called and said they were ready to deliver, we winked and nodded.Someone told me that they might just drop it off the side of the road since liftgate service is just that. I've had 2 machines delivered from PM before and both times, they used a pallet jack and asked me where I wanted to put it in my garage.
Hmmmm ... I did have two of those (rather longish) straps. Might well have threaded them through the round holes in the machine base, led them upward to a central hoist point above the mill, and made sure to add a cinch strap around the top of the column. That would definitely have increased the safety of the lift. Live and learn!One guy I saw at an auction blew out a dovetail. My mentor saw an X in the turret let go, which was far less disasterous. I always lift a BP by the bottom, with cinch straps around the turret that stop it from tipping. Never had one move a fraction, and safe lifts every time.
