G4000 ELS Upgrade
Will be retiring this tach and mounting the ELS control panel here. That fwd/rev switch is non-functional since I did the Treadmill motor/DC drive conversion years ago, so out it goes too.
Implemented the relay box and the braking system today, works great. Used a 4-ohm 50W resistor and it's not even breaking a sweat. Stopping time from 2300RPM is about 1 second with an empty 4" 3-jaw chuck. It's configured to normally coast to a stop (FWD or REV to STOP) or I can apply the foot-brake at any time for immediate stopping..... Pretty darned convenient.
Just waiting on my ELS parts to arrive, shipping these days is really slow, like about 14-days from my Florida forwarder to my door.
On checking, for some reason, DigiKey canceled my LAUNCHPAD TMS320F280049C EVAL BD order without notifying me. Just ordered it from Mouser. So there will be another delay.
Cleaned-up the lathe a bit:
So, while I wait for bits and pieces to arrive, I've decided to print mockups of the Encoder and Servo Motor drive systems and test for fit. Here's the Encoder system. I think I can trust these enough to start making the mounts and deciding on hardware.
Here's today's encoder mock fit-up, a 300mm GT2 belt would do the trick
The Crossfire CNC Plasma-jet does a wonderful job of making the Servo Motor Mount. This trial was done in 16g, the actual will be done in 1/8"
Hey, and I found a stepper motor I could use as a trial fit! .....this is coming together nicely! :beer mugs:
Turns out just doubling the 16g plates is more than rigid enough for the motor mount. Here's the fit-up for the pulleys and belts. Encoder 80T and 40T GT2 150T belt, Servo Motor 24T and 72T 3M 149T belt. As luck would have it, I guesstimated correctly and ordered all the right sized belts.
Just informed that the boards from @clough42 have arrived in Trinidad and I will have them on Monday.
Enough work for the day, it's FRIDAY! .....time to cleanup the mess I made in the shop, and sip on a couple cold ones while doing so! :beer mugs:
Well, the goodies have started arriving, not enough to accomplish anything tangible at this stage. It should all be here by mid next week.
