- Aug 20, 2021
- 43
One thing I can saw about the tailstock is I absolutely despise the way it locks with the threaded rod down through the center and just a small area to get to it. Not a nice locking lever
Yes, as long as you can find one that has been cared for and not all worn out. Often easy to hide the issues. Worn ways seem to come to mind. Have to have a hell of a good eye to just see that. That is my biggest worry there. I don't plan on a ton of work on the lathe but want something fairly accurate when I do.I would suggest you forget about those cheap imports and look for a good old South Bend, Atlas, Craftsman or similar machine.
Those good old brands will still be capable of making acceptable parts with acceptable tolerances long after those imports have been melted down.
Yah, not overly impressed with the grizzlys more of a bang for your buck. All the extras that come with the PM for just slightly moreI really, REALLY like my Atlas. I built it from parts, so I'm probably biased, but I can't really see why so many people seem to hate them so enthusiastically. Anyways MY Atlas is probably off topic, but I do think there's some value in them. Not as a first lathe, but maybe as a third lathe. Did you say you weren't interested in the Grizzly lathes? They are pretty good to deal with imo.
$9,000??For new lathe options the PM1022 / 1030 seems to be popular and offers more than many others of that size. It is one of the more expensive options though.
Grizzly offers a slightly cheaper 10x22 but it has a threaded spindle which some dislike, is actually a 9-1/2" swing vs 10" and lacks the power feed on the cross slide.
The 9x19 or 9x20 is another popular lathe of roughly the same size, but several hundred dollars cheaper. It shares many features good and bad with the Grizzly 10x22 lathes. Definitely a step above the 7x class lathes, but not as nice a machine as the PM lathes. Used these are rather common and can be found for $1000 or less if you get lucky.
The new vs vintage debate is unending, but small vintage lathes can have significant advantages over a small new lathe as there are many small vintage lathes that were available with a quick change gear box, but very few new ones under 12" that have one. The only lathe smaller than 12" I am aware of that comes with a QCGB is the Grizzly Southbend Heavy 10 starting at $9000.
For what you will pay for a PM 1030 (often less) you can get a likely get nice vintage 9 or 10" lathe, Atlas, Logan, Southbend etc with more features, but at the risk of wear and hidden damage. New does have the benefit of not getting a prior owners problems with it.
