- Sep 28, 2013
- 4,306
as the Gingerbread Man says "you're a monster"
Have the log stop pretty much wrapped up.
I needed a valve to dump the fluid feeding the advance motor when the log hit the stop. I had a couple of sections from a stackable valve but no manifolds. Since the manifold will only be at tank pressure I made them out of aluminum.
As the log advances it hits the arm which slides the shaft along compressing the spring and opening the valve. The spring also counter balances the arm to bring it back down.
As the saw comes down a quick acting cam lifts the arm out of the way.
That thing is going to be a hydraulic nightmare if it starts to loose pressure anywhere Greg.
"Billy G"
Just looked at this build and had to start at the beginning and read it through. Wow, nice build. I have built several splitters over the years but nothing on this scale. Can't wait to see more progress and nice work man.just the oil volume of that tubing is significant!
