- Aug 6, 2015
- 4,170
So something I recently discovered, apparently the common 10x22 and 10x30 lathes still use change gears, they do not have a true QC gear box for thread cutting.
Many older American lathes in the 9 and 10" class were available with a full QCGB, but it appears on small import lathes only the older (1980s) Jet 10x24PY has a full QCGB.
The Grizzly, Enco, Jet, Busy Bee etc 9x19 and 9x20 (same lathe just depends on who was measuring) lathes use a semi quick change gearbox allowing 9 threads to be cut on a given set of change gears. The Grizzly 10x22 uses a different limited gear box also giving 9 threads on a set of change gears. The PM / Weiss 10x22/30 has a 3 speed gearbox only allows 3 threads on a given set of change gears.
The PM/Weiss 10x22/30 does have a reversing lead screw allowing left hand threads. The 9x19 and Grizzly 10x22 don't (although there are plans out there on how to add a reversing gear for both).
The PM/Weiss 10x22/30 has power feed on the carriage and crossslide, the 9x19 and Grizzly 10x22 only have power feed on the carriage.
As far as I know none of the 7" and 8" import lathes have any sort of QCGB so the 9x19 and 10x22s are not at any disadvantage here, but I had not seen anyone mention the need for change gears on these lathes before.
Just in case you were not confused enough.
I had decided to go with the Precision Matthews PM-1030V-wQCTP-w/2axDRO... would that be a good choice?
I only made the reference to the Grizzly G0602Z because, cost wise, I could have gotten that one and kept the G0704 mill all manual for now, for the same cost.
And yes... I am way passed confusion, hahahahahhahaha
