Drum switch wiring 120 volt
Let me study it for a bit.. I shall return
Ahh, no. That is a different drum switch. You have a SquareD 2601:
I'll do a sketch for you- gimme an hour or so
M
Try this: Swap 5 and 8 if necessary to match motor direction with switch
(don't forget to ground the motor and switch case both)
Edit: remove sketch- different switch
Popping the cover off, I don't think this is an actual 2601.
And this seems to be the crux of my problems, I think someone put one cover on a different switch. Not an unusual problem with buying used, but something to be aware of. The internals appear to be the hockey stick type, as opposed to the chop sticks a 2601 should have.
LOL I thought about that possibility- yeah someone must have switched covers or there are two versions of 2601
Edit: remove sketch- no P2 wire present
Edit: remove sketch- wire count question
Does the motor have 6 wires or 7? I only see 6 in the photo but on the motor dataplate it shows 7
The pic of the test hookup in post #9 doesn't make sense to me
No Post #9, the dataplate shows:
P1
P2
2
3
4
5
and 8 that's 7 wires- what's up with that?
How did you have it wired to test it?
