- Nov 15, 2020
- 139
Your threads on making a spool require drilling a center. So...Tail stock out of alignment.
Make a spool to check it.
Search my posts for a detailed instruction on making and using.
Sent from my SM-G781V using Tapatalk
A drill will try to self center - even with it being out of alignment. This doesn't explain why it isn't drilling into mild steel (it does explain why you are breaking small bits).Ok, so I ran it on the highest speed today, and I now see that my center drill is mildly shaking vertically, which I suspect is the problem.
So perhaps it is alignment after all...
In the old bays you marked the center with a square and drilled it on your bench.Your threads on making a spool require drilling a center.
When I use the chuck, it moves slightly up and away
