- Nov 15, 2020
- 139
Have a South Bend 9a that I mainly use for turning work from the headstock. I have no problem turning 1/16"+ steel per pass -- so plenty strong. However, I went to drill some holes in the end of a 3/4" rod to turn a piece on center, and I'm having a heck of a time getting holes that don't require a lot of force and end up breaking my bits. I have Keo's, so I'm not working with cheap bits.
If I put a dead center in my headstock and tailstock, and use a magnifying glass, they look in alignment. So even if I'm slightly out, it shouldn't be enough to cause any issues.
I've tried both using my Jacobs 14N chuck and countersunk collet holders. When I use the chuck, it moves slightly up and away when I hit the bar with the bit, but the collet stays steady. I can't get any play by hand. My tailstock does seem worn, but again, can't imagine that could be causing such a problem.
Any idea what could be going on?
