B
Bill Gruby
Forum Guest
Register Today
That's called NAG for short or Noggin Aided Drafting. Use it all the time. Most pros do.
"Billy G"
"Billy G"
Location of the holes may depend on the mating part, and not relate to the center axis of this part, i.e. if this isnt a rotating part, locating from the center may be irrelevant. Check how this fits up, and if applicable, call out the measurements you want to represent your design intent. For example, it may be more important that the c'bore to c'bore distance is more important than the relative distance of each c'bore from the imaginary center of a non rotating part...assuming it doesn't rotate.It appears to me that you have not actually located the holes. I can infer where the centers are but it's best to be explicit. Have you studied geometric dimensioning and tolerencing?
I tend to put some chicken scratch on a piece of graph paper and start cutting metal.
The chamfer is more easily dimensioned and produced (on a manual lathe for instance) as an angle with a dimension in one plane, for example .031" X 45° from the theoretical sharp corner in either the Z or X axes.
Thanks BillNot bad at all,first CAD drawings I have looked at that I did not have to spend my entire morning coffee time reading them to see what was there. Kudos.
That said, I often over-dimension on drawings for my own use because 1. it is convenient for me when I am in the shop not having to do the math to check a measurement and 2. because I know what the design intent is and which dimensions are critical. I have used parentheses around a dimension to indicate for reference only for drawings sent out to a job shop.
attached are some updated files, now i just need to see about dragging my butt out to the shop to finish making these parts. It's 40 degrees in the shop, and even if i run the heater for a while I doubt it will get above 50.
When I first started drawin "professionally", I used to run the drawings past our well seasoned draftsman. He was almost always able to pick up on some missed point. I guess that is why they have the "checked by" and "approved by" boxes in the title block.I made the mistake of showing a draft to someone who's in college to become a mechanical engineer. Bad idea!
Looking at your updated drawings, I would dimension to the centers of the two remaining holes and I would use vertical ordinate dimensioning to locate the center of the radius of each groove. Is drawn, the bottom groove cold be as much as .010" away from your design dimension based on your box tolerance.
