- Dec 18, 2019
- 6,474
The magnetic read heads are definitely smaller. It was a challenge to fit in the 70mm glass read head onto my lathe. FWIW, my factory mag DRO installation blocked access to the gib screws. It didn't block access to the lock though. But the factory DRO resolution was only 0.001" radially, which was too coarse.After looking at the glass scales carefully, I cannot make any of them work. If I mount the read head between the ways, the scale must cover the lock for the compound rotation. If I mount it outboard of the ways the entire backsplash needs to be redesigned including moving the whole machine out some. I think I am stuck with magnetic scales, unless someone comes out with a read head that is 50mm long or less.
I just need to optimize the magnetic approach. At this point that may mean buying an Electronica scale and see if I get improvement. The Ditron is nowhere near their published specs.
Good luck on your search for a smaller mag read head. If I find one I'll pass along a link.
