- Mar 25, 2013
- 4,615
I set it up like this:
My 123 block measures 3.0005 in length. My DRO is reading this as 2.9986. That is an error of .0019. Way too much to accept.
On the 2" side I get very good correlation. I just seems like the scale is off in certain locations.
DRO Pros try very hard to sell their displays, and I've heard from some people that they can be pushy, but what he told you is a pile of BS.Very interesting. Yes I think this is what I am seeing with similar error ranges.
So I called DRO Pros to see about using an Electronica scale. The gentleman there told me I should not use an Electronica scale, that the pin outs were different, that resoldering the DB9 connector was impossible and that the new scale could have different amperage and could break the Ditron display. After going through all those reasons he tried to sell me on a whole new DRO system from them. Very frustrating and not super helpful! Do they also sell used cars?
Yuri- I know you will know this answer. Is the pinout of the Ditron slim head different from the Magna Slim? I assume you have worked with both.
Makes sense. I was in the same spot. I have Rockwell 11x24 and the cross slide must have been purposely designed to make it as hard as possible to install a DROAll great information.
My scale is SLIM 1um. I cannot really fit a full size head due to multiple geometric factors. I have played with the ride height but it did not seem to change much. It is difficult to set the height to exactly .5mm. I have the slim scales so the stainless cover is recessed from the sides and protected by the wipers on the ends. I will make a .5mm shim gauge and attempt to reset the height.
I saw the reverse engineering or the pinout on your site. It clearly can be done.
I would love to just do a glass scale but they all appear to be too large. My lathe is not well designed to accept a DRO scale without interfering with something.
