- Jul 28, 2017
- 2,386
I too dislike wasting material when I don't have to, but sometimes you don't have much of a choice.A carbide bit would definitely either make a straight hole or explode. I didn't even think about carbide drills existing at sizes this small, but they do. It's not the worst idea, and carbide bits this size have larger shanks that would be better to grip in a chuck. Or probably large enough to grip in an ER32 collet for that matter. That's not a crazy idea, although the chances of the bit exploding are very high.
The work was just floating in the air, up above an empty chasm. I tried throwing a parallel under it, but I didn't have a parallel remotely small enough. Chuck spider. I need to think about that. Or a pot chuck could work. More to look at there.
Or I could just throw away a few inches of brass. I'm only making three of these, or whatever number I end up having to make to get three usable ones.
Good food for thought.
I've found that I sometimes can use smaller pieces by gripping them from the inside with an expanding mandrel. I have a mandrel set, and also have made a few. They're not too hard to make if you've got a lathe.
