- Jan 31, 2016
- 11,474
I'll give that a wack also....
I have a BFH if you need one !
Oh BTW, you don't need to mark the cam lock. It's already marked. When you tighten it, the mark circled in red should fall in between the 2 arrows circled in blue. It doesn't need to be exactly where you made your mark & may not be if the chuck is indexed to a different cam lock pin.
What would help is dab a bit of red paint or whatever color you fancy in that little line circled in red. Makes it much more easier to see.
Will, the one lock did not have a definite punch mark, so I marked them all. A 23" 1/2" breaker bar to 3/8 socket adapter got it loose. I like to sneak up on breaking things......
