H
Hukshawn
Forum Guest
Register Today
AND... why can't it cut imperial as it seems to be designed to?
So I did the test. Set the gears to metric, set the gear box to 1.5..... guess what it cut...?
A 1.5....
16 didn't fit
Edit - I just hand cranked the lathe in front gears.
Boy, was I wrong! So much for theories, but I can't believe the math worked out like it did. I'm going back to something I know. Checkers, anyone?So I'm freezing in my underwear in the garage...
I set up to cut a 1.5, a 2.0, a 2.5, and a 3.0. All match perfectly in the thread gauge.
Cause it's in Canada?AND... why can't it cut imperial as it seems to be designed to?
Shawn, I bet it can, we just have to find out how.
That would be next question to answer which all the fellas here can help you with.
From the video it looks like you are getting the hang of using the half nuts. The 'slop' in the lead screw, half nuts and gearing in the apron might make it just a question of practise so you can get a feel for it and pick up the right point on the lead screw every time.
However, considering that your thread dial has 16 segments it does not make sense that it have a 14 tooth gear. That renders it useless for anything. The teeth have to correspond to the marks on the dial, which means a 16 tooth gear is required.
Yes, exactly. I suspect that the machine originally had a metric leadscrew and has transposing gears. With the original screw setting it up for metric gave you metric threads and the dial worked (to the limited extent that threading dials ever work for metric). Setting it up for imperial threads gave you imperial threads. A previous owner replaced the metric leadscrew with an 8TPI one. This reversed the effect of the transposing gears so that to cut metric threads he had to set it up for imperial, and vice-versa. The threading dial became useless.Yes, set it up to cut a 1.5 mm pitch thread. That is, set the adjustable lever on the end gears for metric and set the gear box for 1.5 mm. I'm thinking that will make a 16 TPI thread with the 8 TPI leadscrew that's on the machine.
Tom
Ha, both my wife and I have macs, the only pc we have has a gnarly virus right now.If u are patient enough and somewhat computer familiar, I can download a file that will install, on a windows computer, a program that lets u set up lathe gears in any possible combination and results tpi or metric. Or start with thread spec and tells u what gears u have that will work. I got it a couple of years ago ..... once the variable entries are set up for your lathe, you will know exactly what thread(s) can be cut. It made my Chinese lathe behave !! Tried to download it in this post, but the forum's safety won't allow .exe files thru.
I "think" I have another program for dimensioning gears ...somewhere...
