H
Hukshawn
Forum Guest
Register Today
I will have to research now to do that.I don't think you can rely on the diagram. I think you have to count teeth and do the arithmetic.
I think it's safe to say I won't be using the thread dial anymore. it's turning out to be fairly useless on this lathe as is.Metric threading dials are crazy. The 14 tooth gear that’s on the dial now is one of a set of 5 interchangeable gears that usually come with a metric threading dial. See post #100 in this thread. (no pun intended)
Tom
Ya we've done that. selecting the metric gears does give me the appropriate threading. but the imperial setup does not. each gear box setting gives me 1/2 to 1 tpi less than what it's set for. totally not consistent and unable.You did indicate that the lead screw had 8 threads per inch. So with that in mind all you need to do is get the gearing correct. Looking at the chart on your lathe I believe all you need to do is flip two of the gears to get it to cut imperial threads. Ken
