so, here are my two main issues that i just cant wrap my head around...
first - with the half nut engaged the whole time and reversing the lathe back to the start position. i had the machine set to 16 tpi but it cut a 15... how can that be?
second - when i use the thread dial and disengage the half nut each pass, i have to use the same number each pass, without changing any depths or positions, each cut is 1-2 thou in front of the previous cut. if i carried on long enough, i would eventually over lap my first cut. and if i try to use a different number or line as you can with an even number tpi, the cuts are in a totally different place. ill end up cutting between threads.
I can reproduce this problem exactly on my lathe.
My lathe also requires a different gear alignment when changing to metric and back. The same gears but meshed differently. Sometimes I overlook having to realine the drive train back from metric to inch.
The problem of getting an offset with each pass when using the half nuts is typical of this situation.
The 'good' threads shown in your post 68 when not using the half nuts but producing the wrong TPI is also typical of having a metric gear mesh when cutting inch threads.
Your posts 21 and 105 show the thread charts but I am suspicious that the gear diagrams might be mislabelled. The top diagram is labelled mm but might be for inch threads. Compare your diagram with Pierre's in post 102. What if there is nothing wrong with the lathe and simply using the 'other' diagram solves the problem?
