- Mar 25, 2013
- 4,617
They tried that on Apollo 13... I would avoid it.You guys ever, "stir" your tanks?
Robert
I would love to read that. Nothing that I've read leads me to believe gases will stay separated like that.All of my mix gas bottles have a valve with "DT" on the stem. Some call that a dip tube, some a siphon and others an inductor tube. As I've read, it draws from two different parts of the tank (Co2 near the bottom) to help draw them out in the correct proportion. Look at a 100% argon bottle and it won't have that "DT" stamped on the stem.
Going off a number of threads, the dip tube/siphon/etc might be more for mixing as the tank is filled, rather than for mixing output. Found this:I would love to read that. Nothing that I've read leads me to believe gases will stay separated like that.
[Edit: Re: [USER=23938]@rwm Robert's Apollo 13 reference to "stirring the gas tank" begs the question - why did NASA bother? I get it they were stirring what was a liquid at the time (Oxygen). ]
Ohooo - I do like that! Essentially flow meters in the separate gas lines from bottles of Kosher pure.By the way graham-xrf, what you need is a Frankenmixer. You can mix any percentages you want. And it works, plain and simple.
TIG kit. Selection and costs.
Here I mean the handle, tungstens, pink cups, fittings etc. Everything other than the welder itself. This is a whole other research that we trawl eventually.
