- May 27, 2016
- 3,470
OK - now we get onto territory I have more knowledge on.
Thanks to @cbrasher for mentioning the regulator. The calibration of regulators does depend on the gas density. So yes - you do get regulators that are calibrated for Helium, Argon, Oxygen .. whatever. This is OK so long as always, the proper gas is in it's own color coded cylinder.
Of course, it's a darned pain if you have gas mixes. You can have a lookup scaling factor to let you use a regulator for one gas, adjusted for another, or a mix. Here is where one can get out the old high school notes about partial pressures.
I forgot some gases are sold by weight. Of course they are, especially those that are liquid under pressure, like butane.
It gets complicated with stuff like acetylene, which is shipped dissolved in acetone.
I did not know CO2 has a liquid phase. I know that I needed compressed air filtered completely free of CO2 to stop it turning solid and blocking dewars when used for cooling IR cameras, and I watch frozen CO2 turning from solid straight into gas without going through being a liquid (dry ice). Maybe CO2 can be liquid at high enough pressure - I don't know.
The volume of gas you have is escaping into standard atmospheric pressure - is that about 14.5 pounds/sq inch.
The way to figure how much gas you have to use is then the volume of the cylinder x the pressure in it when "full", divided by standard atmospheric pressure.
Volume available = (Volume of cylinder x pressure)/(standard atmospheric pressure).
Definitely there is more to using CO2 than just the (attractive) lower cost. As @General Zod has mentioned, the character of the arc, the behavior of the weld pool, and the penetration of the weld are changed. Of course, I am just setting out on welding stuff. Clearly I cannot simply buy and try set of gas bottles in all combinations of weld mixes. I had to get the real solid information.
