- Dec 24, 2020
- 1,045
To add just a bit to what General Zod said, 75/25 (argon/Co2) is very common for short-circuit MIG, but if you want to get into spray transfer MIG, you need a higher percentage of argon. Here in the States that usually means 90/10, 95/5 or 98/2. Not all welders have enough power to get into spray transfer mode, so it may not even be an option for you.
Using a MIG welder with a spool gun or push/pull gun for aluminum requires 100% argon.
Using a MIG welder for stainless steel requires one of several blends....helium/argon/Co2, argon/O2 or argon/Co2.
TIG requires 100% argon, or an argon/helium blend.
