- Sep 20, 2012
- 560
I used to own a 10" atlas and had timken headstock bearings, i ran mine cold with .0005 clearance which is a little tight they should be about .001. The bearings are not that bad if you look around i got new out of calf. for around $250
Interesting that it ran OK set up like that.
The book says the bearings should be preloaded, adjusted after running the lathe for 30 min to an hour to warm up (a rise of 50deg fahr increases the spindle length by.002 between bearings) the end float should be taken up then the thrust nut tightened by two teeth on the spindle gear to set the preload.
Bernard
