- Sep 3, 2012
- 311
Been fighting with this, on and off for 4 weeks now. Held off asking for help , it s my nature to try to figure things out for myself. If I don t get this soon I ll have to read the instructions here as to how to post pics
Info:
Cman 101.28940
Had this lathe for 5 yrs now and it has been great. I understand the limits of the Cman/Atlas. Cut every thing from mystery metal to 4130 easy cutting with great finish & control. Cut tapers, fine, and easily set back to almost perfect. Overall, really satisfied with its performance, fit and finish. Parted mild steel with no probs once I learned how to properly set it up.
Lathe worked great for my hobbyist needs.
Had to take the lathe apart to move. after re assemble, is when the chatter started. I leveled(Machinist level) the bench close first. Put the bed in the table& re leveled. Assembled all the components and re-leveled, again with the Starett level
In the last 4 weeks, re ground at least 12 HSS tool bits...Tubalcain style, Barry Young style, Tom Griffin style, all pretty much the same, with subtle differences, for RH tool. Chatter pattern looked the SAME for all
Using a QCTP from Tools for Cheep. I even put the old lantern back to see if any change....SAME
Gibbs. re adjusted, to the kinda tight side, The saddle, cross slide, compound ... SAME
Checked, re checked to to be on center. Tried a little low & high....SAME
Used my new 4 jaw, old 3 jaw, collets. SAME
Took lite cuts for below steps
Turned & faced 1 in mild steel, 2in stick out .. SAME
Set up a 1in x 18 in mild steel on centers.
Reset the tail stock gib to the tight side
Turned near the chuck, & near the tail Bad at both ends, but a bit worse at tail. Really bad at center, Don t have a follow rest, never really needed one...again SAME
I put a indicator on the operator side of the spindle, and had .004 out when I pushed the belt engage lever. Thought that I found it.
So,,, Took the spindle shaft out yesterday (BTW using the green HF link belts) Have a pal that builds racing rear ends for the last 40 yrs, He's the best bearing and race reader I know, come over to help. He sez brgs, & races look fine! Re assembled And HE set the spindle nut to the tight side. Indicating a half thou now. ..SAME
Re checked the bed level again
After all this cuts look as bad now as it did when I started. Like NO change!
I think it might have something to do the re install.
Going to take every thing apart on the left/head side and hopefully find something
Anyone have the ordering phone number at Precision Matthews:thinking:
I ll try for pics later
Tks for any suggestions
ed
I use the the
Speed x 4 / dia = cutting speed
I have tried all the lower end feeds as well.:thinking:
Info:
Cman 101.28940
ed
I use the the
