I would definitely check the head to bed bolts again. Maybe you forgot a washer and the bolt thread is bottoming out before it can snug up. Just throwing stuff at the wall, maybe something will stick...lol
Agreed...Excellent advice!While you are messing with the head mounting bolts, you might just want to take the time to remove the headstock from the bed and make sure that there aren't any chips, dimples, dings, or other high spots in between the two. If you find anything that looks suspicious, you might want to stone it very lightly to see if it is a high spot or not. If you find any, they'll have to be addressed before you remount the headstock.
Spindle bearing $$$$
Class 3 Industrial bearings
14276B $189. bearing
14125A $138. race
16284B $242. race
16150 $269. bearing
Total $838. from local supplyer
Bearings was more$$ $1314.44
Don t think that I will be changing brgs.
I paid $500. for the Lathe
