- Feb 17, 2013
- 4,406
Regarding temperature -- that's going to be a personal choice. I myself prefer the highest "temperature" I can get - 5000ºK or higher. Don't like the "warm white." But it's a personal preference.I've got (4) really neat dual 4'ers from a Western Electric plant - they have great reflectors on them.
Time to retro fit them.
The question I've got for you guys that have gone LED - is what 'color' should I go with?
I've been over to a friend's auto shop where they have re-done the 8' tubes with LED Daylights.
They're hard on my eyes.
Should I go with something lesser temp? My ceiling is only 8.5'
Also I have to convert these and they have oddball 'push' type sockets in them.
I'm trying to figure out which bulbs to purchase from the big box stores, so if anyone has any suggestions...
-or- do the big box stores even carry 'conversion' type bulbs?
Regarding the pin style - You may well be out of luck as far as commonly available "conversion" LED lamps are concerned. The only 4 foot LED retrofits I've ever seen in stores are bi-pin units (two small pins on each end) that are direct replacements for T8 fluorescents. I do have fixtures in my shop ceiling that take lamps with a single (~5/16" diameter) pins on each end, but they're 8 footers. To retrofit LED tubes, you remove and wire around the ballast.
Don't know what to tell you about retrofitting your fixtures. They do look like they have great reflectors!
