Day 29: Finishing the breaker
As you may have noticed, I'm slowing down recently
Between being a little discouraged by a few issues and picking up the shaper (and making a 2 part vise!), I'm sorta working on 2 things at once. I AM doing my best though to make sure I finish at least 1-2 parts a day if at all possible.
I started with the isolator part, the other half of the breaker contact. I had a big chunk of plastic in my offcuts pile that I have no idea what it is from, but I milled this part off the end of it. The plans only ONE dimension (the width), so most of this is guessing/seat of my pants.
I had to drill a mount point on one side, and tapped the other for the contact. The tapped hole ended up stripping when hand-threadng it in, so I ended up fine-tuning the contacts in a different way later.
At this point, I've drilled and tapped the 2-56 hole (to the right of the crankshaft) in the breaker plate. I drilled a #32 clearance hole for a 4-40 to mount this plate, at htis point I'm in the mill finding that hole so I can drill and tap to mount the breaker plate.
I also took some spring stock to get the breaker 'return' working right. This .029 material seems to work great. The little tab on the bottom is supposed to catch it/ be sprung against, but I must have missed that it isn't when assembling (and put it under the bolt to keep it in place. I ALSO soldered the contacts in the two places they belong. On the isolator part, i ground the head of a bolt near clean off, then electrical-soldered (whatever the solder electrical people use is referred to these days, no longer Pb). its contact to it. On the brass breaker arm, I just soldered it directly to it.
