- Aug 3, 2017
- 2,437
Day 22: Starting the Carb
I have been looking through the plans, and am a bit stuck on what I can make based on waiting on materials/tools, so I decided to make the body of the carburator, the only part I can actually make of the assembly! The plans are VERY quiet about the design of the carb, and seem to expect I know more about them than I do. The dimensions are missing on a lot of it, so I end up having to guess on this a bit. This part is pretty clear, but the other two components are a bit confusing. If I cannot figure out how to do it I might post a picture of the plans and make you guys help
I opted for brass, sadly I only had 1 1/2" brass. I first turned it down to about 1/2":
Then I did a rough shaping. In general, this is just preference.
The instructions to the plans claim that the drill-through is only 1 of two dimensions that actually matter on the carb (the other being the OD of one of the other parts). I drilled through, and then used a larger drill bit to create the taper (which is apparently unnecessary as well).
Then I parted it off, turned it around, then used a die to cut the threads:
Next I need to drill through for the jet/needle parts. That went very easy.
Then I rotated it 90 degrees to drill through 1/2 way for what I believe is a throttle screw (for lack of a better term?). The throttle screw is #2-56 in the plans, though again not sure how necessary that size is. Everything went well until it went to retracted the tap and a few turns it broke. It broke near the bottom of the hole! I was actually able to use a pair of pin tools to spin it out (like a tap extractor!) and managed to save this
And installed! The throttle screw right now is pointing the other way, so I'm sure thats wrong.
