- Apr 14, 2014
- 3,149
Keep i mind the "Drill Doctor" is targeting an audience that probably sharpens half a dozen drills a month, not a commercial shop that goes through a hundred or more in the same time period. My first drill sharpener was a Drill Doctor 750. I purchased it when I was in a pinch for a sharpener. I had purchased a Darex M1 machine from the company I worked for, but it was stolen before I could pick it up. I needed a machine in a hurry, so I opted for the DD as a short-term fix. It worked fine sharpening 50 or more drills a month for several years. Finally, it wore to the point it was no longer useable. I had given up on finding a good sharpener at a reasonable price, so I just started buying drills in bulk.IMO Drill Doctors are garbage. That's why Darex dropped the line after a year or so. I have had Black Diamond but it only went up to 1/2" and I never could find a point splitter. Now I use Darex M series and I take damn good care of my chucks because when they freeze up you are done.
If I spin a drill in a chuck the drill shank WILL be scored. I reverse the bit and chuck it in the lathe with the shank sticking out, spin it up and stone the shank smooth.
I buy 10 packs of 1/8" double ended starter bits. I use those hard and throw them away. Bigger, I buy as needed. Silver & Deming bits work way better if they are sharpened well.
A year or so later a friend asked if I was interested in purchasing his Black Diamond model 65 drill grinder. The model 65 is unique in that it was built for the military. It has a 220/440-volt 3 phase 1/3 hp motor and can sharpen fractional bits to 3/4". He had bought it as part of an auction lot from a National Guard repair depot that was closing down. We arrived at a satisfactory price and the deal was completed.
I'm not sure why the repair depot even had this particular machine. They didn't have 3 phase power, so it sat in the storeroom from 1974 to around 2015 when it was auctioned off. It was missing a few bushings and the part of the point splitter, but otherwise in like new shape. Since I've had the machine, I've sharpened well over 1,000 drills with it. I kept the old DD750 and use the point splitting feature when needed.
