Anyone else get carried away with 3d printed tool storage?
@7milesup - thanks! Your link looks incorrect - looks to be spam site trying to install browser extensions. I assume it should be tnutz.com.
Cripes... you are correct. Thank you for the heads up. It has been corrected.
Anyone use DeWalt 20v tools?
I've acquired a few more batteries, so spent a few hours modeling a wall mount rack to organize the batteries.
All of the models I'm finding on thingiverse and printables are too squared off, and don't match the contours of the battery very well.
The model is'nt quite finished. I still need to test print one and make final adjustments, to make sure the battery fits right. If/when I get it dialed-in and the fit correct, i'll post the model on Printables.
Small tray for large tap sockets.
Along the same lines as the DeWalt battery rack, there's a model on Thingiverse that lets you install spade terminals and use it as a power supply.
I made one to power my TS101 soldering iron. It's nice when you need to solder something too big to drag nearer an outlet.
Hi Ken,
I got some new collets in last week and downloaded your R8 Collet holder off Printables. I haven't printed anything this big yet on my Prusa, I probably should have leveled and calibrated my Z before I just loaded and hit the go button. You can see a little artifact on the bottom of the middle front hole. Other than that, the model is perfect for a wall mount collet holder. Worked great!
I also notice that these work for ER32 collets. Do you have a version of this that has the lettering removed or with the ER32 lettering? No biggie if you don't.
