A New Home for my Karl Benz Engine
I was able to get some shop time today and tried my hand at making sprockets.
These are 10 tooth and 30 tooth sprockets for #35 chain for the final drive.
Polished and installed.
More gearing to design for the internal parts.
Thanks for looking
Ray
Thanks savarin
Things will slow down now that I have to figure out how to make a gear reducer and differential.
Ray
Thanks Chris I am starting to work on the gear reducer now.
Ray
This thing is more complex than I knew!
Hey there is a wheel chair in the trash down the street. The rubber tires look like good material for this project. I know you already have tires...just sayin...
Thanks Robert
My engine runs faster then the Benz did and my output pulley is larger in scale so I will need a gear reducer to slow things down. I think around 1 to 1 1/2 mph should be about right for final speed.
Ray
After much ado I did get the housing completed. It is a double reduction gear setup centering around the fixed center gear that makes for spacing the other two shafts critical. I did fudge a little on the first shaft to get a nice tooth depth but the last shaft was right on spot. Don't know how that happened but I will take it.
Now I will try to get this positioned in the frame next to the engine. I can already see some interference problems that will have to be worked out.
Thanks for looking
Ray
