- Aug 3, 2017
- 2,437
Remember that you're going to need shims that long too! The shims for the 2nd/3rd cut that come with the broach are only going to be ~3/4" long.
Also, as was mentioned above, that is a LONG cut for a broach. I'd be quite afraid that it would be too much chip load for the teeth. You might find value in backing it out/clearing chips about 1/2 way through the hole, particularly if the force require to push it increases significantly.
