1/4 of the way to a mill
So the big downside to an MT taper is that the drawbar thread isn't standardized, and much of the chinese/ebay stuff makes poor documentation out of which it is. For MT4, I discovered 3 different threads, 1 of which i could buy tangs for, 2 of which I had drill chucks/centers for :)
In your case, you may wish to pick up a couple rods of 4140 and just make yourself 1 drawbar of each thread, otherwise you'll find yourself needing to spend 2x to make sure you get holders/etc of the right pitch.
Indeed @ErichKeane, I was doing some pre-shopping research last night and discovered tapers with M12, 3/8-16 and 1/2-16 threads.
I like your idea of having some 4140 rods on hand. Forewarned is forearmed!
Something like this will get you started. If you go for one of these make sure the chuck body has flats on it for a wrench.
Need to determine the thread on the current Drawbar.
Banggood, has a 1/2-13 thread. USD$75 cheaper. more collets. Of course with the virus outbreak. . . .
Then later on you can get a couple of these later, and have the collets to use with them.
Little Machine Shop has a decent selection of MT3 tooling. I've bought from them several times and no complaints.
It looks like most of theirs are 3/8-16 and they do specify the drawbar used where appropriate. Some items like the dead center don't use a drawbar.
Little Machine Shop MT3 search
I had two round column mills before I got my bridgeport, I never had any complaints about either one! You will be very happy with what you have!
Ryan
I ended up buying that collet chuck set.
I wasn’t keen on having to make a metric drawbar just to get started.
