- Jun 2, 2022
- 23
Forum and machining noob here. Double whammy. Got a very strong welding and carpentry background, but machining is a new venture for me.
I purchased a second hand Grizzly G4000 lathe (9”x19” I believe). It came with a QCTP from Shars which I believe is AXA sized. He also fabricated a 4 bolt plate underneath to stiffen it up. Saw a video about that after I brought the lathe home.
The tool holders will support up to 1/2” cutters so that’s what I bought. When I went to set the cutter height using one of the centers, I had the tool holder as far down as it would go and it was still approximately 1/16” or less too high with no more runway.
So as a learner bee at the moment it seems as if the AXA sized QCTP is a tad too big and it’s going to prevent me from using the 1/2” shank cutters even though the holders support that shank size. Is that correct? Should I buy 3/8” shank cutters to add in the little bit extra height adjustments needed? I’ve seen in another forum online where someone had a similar issue. The advice generally was smaller shank cutters or having the tool holders machined to be smaller in height.
Kind of looking for the best approach forward and some advice. I would prefer not to mod my tool holders because then it has to be done every time I buy additional. Plus I don’t have a mill in my weld shop. Will 3/8” cutters make a massive difference to the work - negatively - due to being less rigid? I hate that I spent $100 on a set of 1/2” shank cutters that can’t be used. Worst case I can put them up for sale online. Not a huge loss more annoying really. Ideally I would like to be able to use them though.
Anyway, I appreciate any advise. Excited to finally learn how to do lathe work. It will be a heck of a learning curve but fun no less. Just want to keep the expensive mistakes to as dull a roar as I can.
