Yeah, 0.01 mm graduation is not hard to find, and it is affordable. But as I see things, you should ideally be able to measure with greater accurracy than you can machine, because otherwise, you'd loose certainty on those good 0.01 mm accurate parts you're making, wouldn't you?
And I find it surprising that it is so hard to find affordable 0.001 mm or even 0.002 mm graduated micrometers when 0.0001'' are commonplace, and these are very close numbers.
Yeah, I understand the difference between accuracy and resolution, and the role of thermal expansion. But the imperial mics I'm looking at with 0.0001'' usually hace an accurracy between 0.00005'' and 0.0002'' which is acceptable. I have an AC in my workshop, but if that is not enough temperature control, I am willing to call it willful over-engineering.
0.001 mm is just under half a tenth (0.000039701").
0.01 mm is just under half a thou (0.0003937008")
I would think for the majority of small to medium sized shops doing 'paid for' work, measuring at half a thou (given that their tolerances for most parts are likely to be be in the low single digit thou; a couple of thou for example) would be perfectly acceptable.
For most hobbyists, being able to measure at a level of half a thou is entirely sufficient.
Take a look in Machinerys Handbook at the standard fit charts. The tolerances for most of the fits are shown in thou.
I'd think the use case for 0.001 mm metrology would be
calibration of metrology tools in in-house toolrooms not in a hobbyist work shop.
I think you may have fallen into a trap that gets all of us in the hobbyist world (it's a trap that you see in other hobbies too; recreational shooters looking for half MOA at 500 yards for example). We get excited about a level of precision that rarely, if at all, isn't relevant to us.
If you get a genuine Mitutoyo micrometer that has a resolution of 0.01 mm and don't chuck it around the shop, you'll get a quality of measurement that will definitely be sufficient. Here's the relevant specs for an economy Mitutoyo analog mic:
Mitutoyo 103-137 (0.01mm) Ratchet Stop Economy Design Micrometer 0-25mm
- Resolution: 0.01mm
- Accuracy: ± 0.002mm
That will give you a measurement that will be accurate plus or minus about 0.00015".
Now sadly, just like on any forum, there'll be "willy-wavers" who insist that their hobby work demands micron level accuracy. Also there'll be some others who are/were production machinists/engineers and
genuinely forget that this is a hobby forum and have their 'precision production' head on when posting.
Either way, for hobby shop work, a metrology resolution at 0.01 mm should by and large be entirely sufficient.
