Brilliant! thank you. Looking carefully at the table there's an asterisk that says that 103-129 and 103-130 can do 0.001 mm. In other words, the 0-25 and the 25-50 mics can do 0.001. Thanks!
MSI-Viking Gage is a leading supplier of precision measuring technologies. MSI-Viking provides Total Metrology Solutions for precision products, ISO 17025 calibration, inspection, repair, and engineered solutions.
I have a metric micrometer set from Dasqua. That is reasonable priced and the quality is good enough for hobby use (it is by far not a Mitutoyo). It has a 0.01 mm resolution but you can easily estimate the values in between at 0.005 mm.
I am not capable of machining within 0.001 mm. At the best, most of the time, I get 0.01 mm.
Even if you can measure at a resolution of 0.001 mm it doesn't mean it is accurate at 0.001 mm. For that accuracy you need to keep the room temperature constant and have the micrometers calibrated at a regular base.
