- Feb 25, 2021
- 3,271
P = V*V / R, You can figure up to 350 volts, so at 10 ohms you need 12,250 watts.Higher ohm resisters will give you somewhat less braking effect, but also reduce the wattage needed. 350 volts is pulling a number out of the air, the VFD manual may have better info, sometimes buried in the appendix.
You can chain multiple resistors, sometimes that's cheaper than buying one big resistor. For example two 10 ohm 4000 watt resistors in series will give you 20 ohms at 8,000 watts, which would work in the above 350 volt scenario.
