Hi Karl,
So a few things to consider, first would be the motor, as far as I can see that PE284T-10-8 900 RPM (29.7A at 230V) motor does have a 10:1 constant torque ratio but it may be limited in its upper speed (did not see any specs.). I did check a few other motors so something like the PEWWE10-9-284T is rated as 10:1 and a draw of 27.5A. When you get into the vector/inverter motors you are getting much wider operating ranges which should give more linear low end torque. The 900 RPM motors tend to be a bit less efficient and have a higher current draw, and they are darn heavy and big but varies by model. I did some checking on eBay and there are a few suggestions below, I think the Teco 1200 RPM motor which is an inverter/vector type motor and specifies an operating range of 3-120 Hz might be a better option as far as speed range and operating efficiency and also has a has a lower (FLA) current of 25.6A . It should also be able to spin faster, probably 2.5X the base speed. With the Teco inverter/vector you could get by with a size smaller VFD. It is also ~1/2 the cost of the 900 RPM one.
The VFD's I have installed/worked with others using the Hitachi, Yaskawa, Teco and Fuji models. In preference for a lathe application I probably would rate them as Yaskawa first, then Hitachi or Teco, and last would be the Fuji. I use the Yaskawa in both my mill and lathe, I find they are a bit better operating and less issues then some of the other brands. Fuji are the least expensive in their cheaper (mini) units, but I tend to recommend them for situations where I need maximum amps with minimum function. In applications where I need more inputs and programming adjustability I prefer not to use the Fuji lower end drives. I have parameter files for most of these and have done quite a bit of tweaking with the Yaskawa V1000's as well as the Hitachi and can provide you with suggested parameters that I have used.
Be careful in the application of VFD drives in a derated mode, so something like the Hitachi Drives P1-00600-LFUF is only rated for 22A (ND) with a single phase input, the 00800 model is rated for 31A and the 0930 for 36.5A. Many of the VFD's amp/Hp ratings are over inflated for variable torque or light duty, in HD mode of for single phase input they need more significant derating. The new Hitachi SJ-P1 line are very nice, but also quite expensive in particular the size need for derating. There are no native single phase models.
Use of a DC bus choke makes a significant impact on peak current draw and also derating, so you can usually get by with a 1.5 derating, but is VFD model specific. I often will use the MTE buss chokes, you can often find them at good prices on eBay, something in the 40A or 50A (DCA005003 or DCA005004) would work in the derated mode as you are only pulling 25-35A depending on the motor.
Mark
900 RPM Motors
https://www.ebay.com/itm/150282-22-...EFC-208-230-460V-3-PH-60HZ-RIGID/222911199825
Find many great new & used options and get the best deals for Weg Electric motor 284TC, 10HP 900 rpm Severe Duty at the best online prices at eBay! Free shipping for many products!
www.ebay.com
1200 RPM Inverter Vector
Find many great new & used options and get the best deals for NEW TECO 10HP, 1200RPM, 230/460V, 256T, TEFC at the best online prices at eBay! Free shipping for many products!
www.ebay.com
1750 RPM Inverter Vector motor
Part #: TVD215THTL7726FVL. Marathon Black Max w/ Encoder AC Motor. Avtron Encoder New S urplus. Part #: AV56A 1CBE8XP000.
www.ebay.com
VFD's to consider based on the PE284T-10-8, you could go down a size with a higher efficiency motor.
Hitachi Wj200-150lf (60A in CT (HD mode) and 35A in derated mode for single phase, would use a DC buss choke)
www.driveswarehouse.com
If more efficient motor than: Hitachi Wj200-110lf (47A in CT (HD mode) and 27A in derated mode for single phase, would use a DC buss choke)
Yaskawa V1000 CIMR-VU2A0056FAA (47A in CT (HD mode) and 28A in derated mode for single phase, would use a DC buss choke)
Yaskawa, CIMR-VU2A0056FAA, 20HP, 3-Phase, 200-240V (Input), NEMA 1 Enclosure, Variable Frequency Drive
motorsandcontrol.com
Yaskawa V1000 CIMR-VU2A0069FAA (60A in CT (HD mode) and 36A in derated mode for single phase, would use a DC buss choke)
Yaskawa, CIMR-VU2A0069FAA, 25HP, 3-Phase, 200-240V (Input), NEMA 1 Enclosure, Variable Frequency Drive
Teco Westinghouse E510-220-H3-U (64A in CT and 38A in derated mode for single phase, would use a DC buss choke)
20 HP VFD, 230 Volts, NEMA 1/IP20, Teco, E510-220-H3-U Variable frequency drives are a device that varies the speed of a three phase motor.
dealerselectric.com
If more efficient motor than: E510-215-H3-U (47A in CT (HD mode) and 27A in derated mode for single phase, would use a DC buss choke)
E510-215-H3-U quick delivery, authorized Teco Westinghouse distributor. Offers complete line of AC Drives . Easy online ordering, rewards program, and great pricing.
www.wolfautomation.com
Hitachi SJ-P1 drives, see output rating using single phase source
