- Dec 24, 2020
- 1,191
It sounds like CDCO has maybe listened to the comments about the hardware. I got a Bostar BXA starter set last week for a lathe I'm fixing up and took the holders out of the bags today. The set screws all fit nicely in the threads and a 5mm hex key was snug like it should be. I will say the hex broaching on the height adjuster studs was a little less than perfect and all of the adjuster studs needed to be tightened, but I've found that with almost every brand for some reason.Well, my experience is definitely dated. I probably bought the last of my CDCO holders more than 15 years ago, maybe more. When BXA size was $10... The only ones I've purchased in the last five years were the Accusize. The CDCO I bought had terrible fasteners, very loose fit in the threads, no fit in the hex heads, and made out of some lead alloy near as I can reckon from their softness. Still, all that said, replace the hardware and they've been fine.
Top L to Bottom R: CDCO (with new hardware), Accusize, Dorian, Aloris:
GsT
It seems there are two schools of thought on sizing the actual holder...Aloris and Dorian. Dorian makes theirs a bit longer and the slot for the tool is below center. Aloris is a bit shorter and the slot is pretty well centered. I guess some imports copy one style and other imports copy the other style except some of the longer imports have a centered slot, so I guess those are 50/50. I didn't have a Dorian BXA to compare, but your Aloris and Dorian BXA show the same basic difference that I see with the CXA size...Dorian is a bit longer and has the slot lower. Like you said, they all work, but it is interesting to note the slight differences.
For my Clausing the Aloris style is a bit better and for my Victor the Dorian style is a bit better, but only based on where the lower ledge is positioned.
