There is a problem with terminology. You can increase torque with gearing but you can not increase power. No matter what you do, you can't get more "power" out than you put in.
Metal removal often has a sweet spot where DOC, Feed and SF/M all combine for the particular tooling you are using. Sharp tools cut freer but dull quicker. My carbide inserts, that are for aluminum, cut steel beautifully but dull relatively fast. The nicest thing about them is being able to take a very fine cut in steel much like my HSS tooling. I can even sharpen the "for aluminum" carbide inserts a couple of times on the tool & cutter grinder.
Just play with the variables until you find what works best for you.
I've tested to see how much material I could take off in a given time. Pretty amazing actually.
