- May 7, 2023
- 1,644
I've got a bunch of parts to make that require boring out a 2.1" diameter bore to 0.813" in annealed 4140. I've been taking 0.015 per pass. I'm using a 1/2" carbide boring bar with some insert---if it's important, I'll post more details about the tool. No chatter but there's some deflection when I reverse the tool.
Curious what the experienced hands would do in this situation.
Changed the insert, which reduced the spring. A dull insert was causing the boring bar to deflect, I think.
At 0.015, it is very slow going. And the cuts don't sound good. I bumped up to 1000 RPM, which is great at 2" diameter, close to 550 SFM. At the beginning of the job, where my drills top out, top speed (2000 RPM) is only 327 SFM... a little low for carbide.
I tried one of those speed/feed calculators. A cut of 0.020 at 2" diameter, 0.005 in/rev (520 SFM) is about 0.5 HP at the motor. So I guess that's an answer to the original question. The same cut, but 0.033 deep is 0.75 HP. So it seems that I'm limited by motor power, not rigidity.
The insert seems to last better at higher surface footage.
Ditch the calculators and find what your machine will do.
With a properly ground HSS tool you should be able to do much better than .015.
Inserts and machining calculators are not your friend in that sized machine.
