- Dec 20, 2012
- 9,408
I believe this is because of the center of the drill, the chisel edge.
The "wings" of the drill will bite into the material but the chisel edge where the cutting lips meet will resist it, due to having to push the material aside to penetrate thus preventing it from grabbing and suddenly trying to take a huge chunk.
So when you use a pilot and remove what the bigger drill would have to 'chisel' out, you're also removing what would've braked it a bit on entry.
At least that's my current theory.
Not sure I agree with this one. You're saying the center has a "braking" effect ...
A non-dubbed drill has variable rake along its cutting edge; more rake at the outer edges and less as you approach center. A dubbed drill has reduced rake that is more uniform along its entire edge. When using a pilot drill, the edges of a non-dubbed drill that contact the edges of a pilot hole begin to cut aggressively and since the rake of the cutting edge increases as you go further out along the lip of the drill, it tends to take a bigger and bigger bite. Hence, the drill drives itself into the hole and eventually stalls. In contrast, a dubbed drill has even rake angles along its entire cutting edge so it tends to cut much more evenly and this tendency to self-feed is greatly reduced.
When drilling with a non-dubbed drill but without a pilot hole, the drill will tend not to self feed because there is no edge for the outer flutes to bite into. Hence, chip formation tends to be much more uniform along the entire flute and the drill not only does not dig; it cannot dig.
The center does not cut at all, nor does it act like a brake in any way that I have heard of. I could be wrong so please feel free to correct me.
