Yes, saw a video on how to make one out of one of the large water filters that I have:Have you looked into making a silica gel dryer? Media is pretty cheap, and you can even dry it out in the oven to recycle it (or so I've heard, haven't done it yet...).
I have no idea what those 3 items are? Should I know?
Sunnen 1810 hone,sunnen calibration rings, cam big align boring machineI have no idea what those 3 items are? Should I know?
edit: ahhhh a sunnen hone.
nice
So, you have an automotive machine shop setup??? If so, we might want to talk...Sunnen 1810 hone,sunnen calibration rings, cam big align boring machine
That will work. Don't plumb it like he shows though, you want the air to enter at the top and exit at the bottom. The air should pass through the beads without disturbing them for the best results!Yes, saw a video on how to make one out of one of the large water filters that I have:
I use the orange/green beads, I read the pink/blue give off cobalt dust or something like that. I sure Pontiac John can comment if it's an issue. You can absolutely dry them low and slow in the oven.
I've got a Fowler 6" digital caliper. Probably made in China, It was fairly cheap 5 years ago. Batteries last a long time. I like being able to add measurements up by just zeroing as I go and then back to home for a total. Works for subtracting also. I don't use a caliper for getting serious about a measurement because it is so easy to not get perfectly square to the work.Just don't seem to trust electronic systems which is silly
Sort of. YesSo, you have an automotive machine shop setup??? If so, we might want to talk...
With a high volume of air the beads could levitate or boil allowing the air to bypass them, sort of like backwashing a pool filter. If you blow down it guarantees as much intimate contact as possible because the beads cant move. It could be theoretical but why not give yourself every advantage possible?Wachuko's water filter canister has a siphon tube in it, what difference does it make which direction the air flows?
