- Mar 15, 2023
- 70
Especially when it comes with a 10" facemill..hahahaha....
Yeah, with machine tools is when you lower RPM you typically want more torque. This should give full torque at stalled.Small lathes could really benefit from this motor. Easy to fit, and it has coarse steps as well as fine sweep on the speed controller.
I edited the post with more details and links...@wachuko, the table supposedly holds 8 gallons. How big is the reservoir?
I did the deep dive on table coolant, and I think I will use borax (and maybe a small booster of NaOH) for starters, and I'll just paste wax the Langmuir so the splashback doesn't salt up immediately. I plan to drain and dump between uses, and refill using 5 gallon buckets. I'm ready to start cutting test patterns this weekend.
I am curious about how long "green cut" can buffer its pH against CO2 diffusion and oxidation. If it lasts a long time once drained and covered, I'm game to try it. All of the plasma table coolant products use unlisted chemicals, so they can get away with "proprietary" and a totally blank SDS. Makes it hard to know the chemistry when all that the SDS shows is sodium nitrate or a simple surfactant without showing the buffers or stabilizers. Nitrites are not stable in aqueous solution open to the atmosphere, so they're adding something else to conjugate the anion.
XL table takes from 5-8 gallons of water/coolant - I figured an 8 gallon tank would be enough.
Read about mixed results on use of borax... but my take is that it was user error... just need to keep PH around 9 or above. But I am lazy, that stuff I posted worked for a lot of folks... was lazy and decided just to get that instead of taking out the chemist kit... hehehehe
Also got some of these silicone collapsible funnels to modify and place on the torch to minimize the glare and splash when in use...
There was also a best practice of parking the torch on a flat surface after the last cut to minimize the splash from the compressed air... rather than parking it over the water/coolant. I hope that makes sense.
EDIT: Here is the video that made me decide not to use Borax
@pontiac428 can benzalkonium chloride be used with weed killers to adjust the pH of water being mixed in?
My local farm store quite caring pH adjusters that came in a surfactant. I can order out of state but shipping is a killer as you are experiencing.
